They all use the same charge for brush plating.
You can get more solutions from http://www.caswellplating.com/kits/plugnplate.htm.
Note: You need stainless wands for nickel, copy chrome, gold, silver. Copper wands for copper plating and brass wands for brass plating.
Plug and plate ?
Plug and plate ?
I'm sorry if this has been already asked but I don't have time to set and go through the forum ?'s I have the copy chrome kit and have used it to plate some bolts that i couldn't get in Stainless.Do all the plug 'n' plate kits use the same current charge as in the same adapter or are there different settings I was wondering if I could just buy the different solutions etc.I'm hooked now the bolts came out beautiful I filed the markings off the heads and polished them before plating.Thanks
Tags: None
