plastic plating with plug n' plate
  • plastic plating with plug n' plate
    Hi,
    Can small plastic pieces that have been painted with silvaspray be brush plated with copy chrome, or do they have to be tank plated?
    It's best to tank plate them, at least until you get the first layer of plating onto the part. Then you can brush plate other metals if desired.
    You can also use the Plug N Plate kits to tank plate if the parts are very small.
      Re: plastic plating with plug n' plate
      Originally posted by scott1
      Hi,
      :P
      I'm very interested about this?
