Black Krome
  • Black Krome
    I just saw the Black Krome plating kit. It only shows the solution for brush plating. I assume I can order a larger size for tank plating. If I already have the chrome plating kit, can I just buy the solution to do black krome?
    1966 Impala (hers)
    1966 Impala SS 427 (his)
    See them at
    The Watering Hole
    Of course, we can arrange other quantities of the solution as you need it.
    The process uses a Stainless Steel anode, so you just need the solution, an anode or two and the instructions.
