If I drop a nickel plated part into the chrome tank, when I remove it how will I be able to tell if its worked or not? The nickel looks like chrome when I finish polishing it. So it looks the same when I take it out of the chrome tank.
chrome or nickel?
Tags: None
Nickel has a slight yellow tint to it, chrome has a slightly blue tint. They do look very similar, but you should be able to tell the difference, especially if you put a nickel part against a chrome part.
Also, the bubbling that occurs during chrome plating is a signal that the plate is being applied.
If you absolutely have to be sure, try stripping the chrome off again. If you use a reverse brush plating system, you will see a yellow stain on the wand where the chrome is removed. No yellow stain, no chrome.--
