Re: what steps
Hi Matt:
You should direct support questions about our products to our Problem Resolution System (PRS) in the support section of our web site. http://www.caswellplating.com/support.htm
PRS is designed to track your problem correctly, while the bulletin board is not.
what steps
what steps
Hello,
What steps are required to use copy chrome on a aluminum part? I would like to dip the parts in the copy chrome, so how do i do that with theincluded power supply? Do i just attach both aligator clips and dip it in? Also, when using the zincate before hand, do i just put my part on a wire or something and dip it in there?
Finally, how do i store the zincate after each use and how long does it stay good for?
MattTags: None
