what do i need??
  • what do i need??
    ok, here is another question i just thought of. say i had a 1 gallon bottle of your copy chrome solution and the ac power supply that comes with the kit. how do i know if i sufficent power to chrome a part in the one gallon contaier? i could use the 8oz container but i would have to do 1 dip on one end and the 1 on the other to get the full length, versus a 1 gallon conatiner where i could do one single dip(assuming one dip is enough for a good coat).
    thanks again
    matt
    Re: what do i need??
    Hi Matt:
    You should direct support questions about our products to our Problem Resolution System (PRS) in the support section of our web site. http://www.caswellplating.com/support.htm
    PRS is designed to track your problem correctly, while the bulletin board is not.
    Thanks
