If I have an aluminum cast bracket that I'm wanting to chrome plate, obviously I have to zincate it first. Afterwards, I assume I can go directly to bright nickel. Is this correct? If, however, I want to build copper on it because the casting is rough and I'm too lazy to grind and buff it down to a smooth finish, after zincating it, do I strike copper it or can I go directly to the bright copper, which is what I want to use for building copper? I thought I had read where zincate won't take a bright copper but will a strike copper. In the triple chrome kits you sell, I noticed it includes both bright copper and a strike copper concentrate. Is this correct? The separate strike copper kit, however, is $300+ which I realize includes the tank, heater, etc. Is this the same strike copper as whats in your triple chrome plate kits? I'm interested in the 4 gallon kit. Thanks for the help!
Strike copper or bright copper after zincate?
Mdarr:
You will be far ahead if you work your base casting to the point you want it to look like prior to the copper plate.
Its a lot more work to work the copper plate after its on then just to finish out the initial casting.
I cant say about the flash copper strike. I go into my nickel bath after zincate and then into copper to build up.
48BUICK
