Need a little help and advice. Testing a Copy Chrome Kit on sheet brass. The brass was wet sanded with 2000 grit paper. Polished with rubbing compound and then Blue Magic Liquid Metal Polish. In the picture you can see the upper half is like a mirror as you can see the reflection of the Dawn bottle. The first time I applied nickel plating, it came out dull and uneven. For the second try I sanded the same sheet and polished. This time I washed it thoroughly with Dawn Ultra detergent and water. After plating it came out the same way. In the picture the cloth is what it looked like after removing it from the wand.
So am I doing something wrong?
