what is needed for plating
  • what is needed for plating
    i need lots of help in getting started in plating with copy chrome.
    Re: what is needed for plating
    What are you going to plate?
      i want to plate auto and motorcycle parts.
        i need help on what to order and how to get srarted.thank you
          First thing would be to order the Copy Chrome Kit, comes with just about everything you need to get started chroming. Probably should get Pickle #4 to remove rust from steel. Also get some copper bars for your load bar. Oh yeah, a power supply is needed of course.
          After you have got these parts you should be ready to copy chrome. Make sure you order the copy chrome kit size that fits your needs.
          http://zanodize.com
            can i get a kit with every thing ready to start. thank you
              Id suggest doing some reading on this caswell site all the answers are here just look. You expecting someone to set this up and run your copy chrome? Do some research!
              http://caswellplating.com/kits/combo.htm look at the copy chrome/flash copper kit.
              no there isn't one kit that provides "everything" you need.
              http://zanodize.com
                I bought the wheel Chroming kit I can plate a 20" wheel. Then I had to buy a 35 gal Acid copper, 35 gal chrome stripper, Pickle #4 , and other pickle tanks. I also have built a overhead trolly to hang wheels. Water filter. Dont forget all the sanding and buffing equipment. Let me know if I can help. Thanks, Todd
                  Todd is right get all your pollishing equiptment also
                  the Caswells sale atff can help you alot i know Carig at exten 114 is also useing copy chrome give him a call
                  Jim Eaton
                    thank you. i will call can i the full phone # please.
                      can i have the full phone # please. thank you
                        1315-946-1213 exten 114
                        Jim Eaton
