new solution
  • new solution
    when can you tell when i need to order new cristels
    and how long can a batch sit, dose it get old
    Re: new solution
    So long as the solution is kept sealed they last forever. The only thing you will need to add is brightener when needed. Typically brightener gets used at about 10ml per 20 amps plated (heavy plating). Eventually peroxide will build up in the solutuion and the plated result will always come out cloudy regardless of ph and amount of brightener. When this happens, filter the solution through a carbon (charcoal) filter. This will remove all detergents/peroxide and brightener in the solution so you will need to add the recomended amount of brightener for your tank size.
    Cheers
    Mark
      Re: new solution
      i think you hit it on the nose the last time i filtered it though my crappy carbon fillter it was a little better but didnt think about adding more brightener in
