Thank you.
Pot Metal Or Not?
Re: Pot Metal Or Not?
You can take a drop of acid, muriatic or sulfuric and drop it on the part. If it fizzes violently, it is pot metal.--
Yes, battery acid = sulfuric acid.
You can go to a hardware store and buy some swimming pool/concrete cleaner...that's muriatic acid.
If you are doing plating, having these acids on hand is useful anyway. They're the basis for the pickels used to de-plate etc.--
Re: Re: Pot Metal Or Not?
I think a 50/50 split would be fair--
What kit of ours do you have?
Most likely, you'll just need a Pot Metal Primer kit.--
Then you'll need the Pot Metal Primer Kit to plate over the Pot Metal before Copy Chroming.--
It's not just regular electroless nickel, it's a special Pot Metal electroless nickel.
Yes, nickel can be buffed to a high shine, but the Pot Metal E-Nickel can't. It's not designed as a finish plate.
You bought the Copy Chrome kit because you wanted a chrome-like finish without the hassle of real chrome. You can plate a part with Zinc and buff it to a high shine also, but it's not chrome and won't look like chrome. The copy chrome kit will.--
Not to worry - no offense taken.
The tank needs to be able to be heated to high temperatures and needs to be non-conductive. Glass and ceramics usually work best.--
Also consider the new FLASH COPPER kit. Plates directly onto Pot Metal--
