Clean up
  • Clean up
    Is there anything I can use to remove the blow off emory compound on the garage floor?
    unless your in a pro shop with vents, it looks like your going to have to use a push broom
      A good degreaser will remove the laden compound off of the floor. You should get a large rubber mat and place it under your polishing machine.
        I use a little aluminum brightener,,,brush in with stiff bristle brush,,,,then go over with powder soap,,hose off then squeegee out
        We Dazzle With Brilliance
          I just wipe it up with a rag and some 409. It probably helps I had my garage floor coated with that epoxy stuff before I moved in tho. hehehe
          How 'bout Castrol Super Clean and a stiff brush Works good for removing oil drips from the driveway. (One of these days I gotta fix that leak on the wife's car)
