Polishing aluminum quickly?
  • buckeyevs
    Well..
    the metal is 6061 aluminum and the media I am using is the metal polish treated corn cob you get from Caswell.
  • thesound
    What kind of metal are you polishing? Aluminum? Brass? Stainless steel? What grade of metal polish are you using on the corncob?
  • buckeyevs
    started a topic Polishing aluminum quickly?
    Ok I have a vibratory tumbler and have run these parts through Course, Medium, and Fine ceramic triangles. Then metal polish treated corncob, each having a run time of 6 hours and the result is absolutely not what I would call polished. Is there a trick to using the corncob or should I abandon that procedure? Is there any other method of mass producing a polished finish that can be anodized? manual plishing just takes far to much of my time to be practical. Any other media for the tumbler that would do a better job than corncob? Any help would be very much appreciated.
