I need to polish small bores in both 1/4" and 3/8" ID does anyone have some hits/links to polishing items for these small bores? What would you use for a wheel or bobbin.
SS and Aluminum small ID bore polishing
What type of casting are the bores in? Gun barrels? Pipes? This could be as simple as getting a cartridge sanding roll kit along with a few felt bullet and/or mushroom bobs. (If you can find them that small.)"Some people are like sandpaper: they may delight in the misery they inflict by rubbing up against you, but in the end you will come out smooth and polished while they'll just be ugly, wrinkled, and used up." - Beyonce Knowles
