I have a custom aluiminum truck cap. It was finished with a deco wheel
which gives it a swirl finish. It was not sealed and has since oxidized badly.
I have tried all the products at the auto parts stores an none have helped much.The material is quite thick and sturdy. What I would like to do is finish the entire cap to a mirror finish. What do you all recomend as far as compounds and buffing tools? What speed should the buffer run at and what types of pads should I be using? Can I seal the aluminum with something like Zoop Seal to stop the oxidation. Is there a better sealer? There are no deep scratches in the aluinum just the light swirls. Please help!
