polishing ali tubes
  • polishing ali tubes
    Hi all, i need some advice on polishing fork tubes prior to anodising.
    currently i use my lathe, and start removing the scum produced by stripping the anodise with fine wire wool, then 400, 600 1200 wet and dry, then use a proprietary aluminium polish on a soft cloth. i get a nice deep lustre, but get swirl marks in the direction of rotation.
    what would be a better method ?
    i have a 2hp bench buffer, BTH i really dislike using it, especially on long stuff. but if needs must etc.
    TIA
    "A stupid man's report of what a clever man says is never accurate because he unconsciously translates what he hears into something he can understand.
    Custom Anodising
    Re: polishing ali tubes
    are they marks left by your sanding process or from the last aluminium polish and cloth. if they are from the sanding then you should try a cutting compound before the aluminium polish, if they are from the polish then you should try a different combination of polish and or different cloth, youi could also try a swirl mark remover like the pros are using when polishing car paint.if nothing else then you could find a 7 inch variable speed polisher/ sander and use as a buffer with the proper compound and wheel on the tube while they are spinning in the lathe
    http://www.peintureenpoudrepb.com
    http://www.polissagepb.com
    http://www.powdercoatpb.com
    baz
      possibly a combination of both, i took them and sanded with 2000 grit longways and hit the buffing wheel with a little blue compound and they came out like glass
      I have machined up a plate to fit on cross slide to bolt a bench grinder to and use auto feed, but havent got round to fitting it yet, i use the lath for machining more than polishing so its a PITA re-setting everything up, maybe i should get another one the wife'll go mad LOL
      Custom Anodising
