hello all,just wonder if when stacking wheels on a shaft and their not in perfect alignment with each other can this cause small ripples on the work piece?is there room to play + or - a little bit?
using two 8in loose cotton wheels at this stage,and one is sitting just a bit
higher than the other on the outer edges.
any input would be great,thanks.
