I am having trouble with the famous cloudiness during polishing. Usually I have no problems but for some reason (I think it may related to air temperature in the workshop) the wheel is depositing compound on the aluminium. This always comes in 2 forms :- either dark blotches (which is solved when I apply more compound to the wheel) or cloudiness because the wheel is not taking the compound off the surface. The part itself gets really hot when I'm polishing but the temperature in the workshop at this time of year is around 6degC (43 degF). I was wondering if anyone else was having this problem or perhaps the compounds were designed to work at room temperature?
I am using 2 stacked 8 in. wheels on a 2900 rpm 3/4 hp spindle with a tripoli and white compound stages on spiral sewn and loose cotton wheels respectively.
