Question regarding composition of buffing compounds.
  • Question regarding composition of buffing compounds.
    I just bought a buffing compound kit, and I was checking the SDS documents to see what the composition of the bars was. I was under the impression that the green bar (stainless), was green due to the color or chromium oxide, however, the SDS sheet does not show chromium oxide as a component of that bar. Is that correct or is there an error on the data sheets?
    https://caswellplating.com/content/s...20Compound.pdf
    The SDS sheets are correct.
    Jason Vanderbroek
    315 946 1213 x116
    www.caswellplating.com
