New to the metal polishing thing
  • New to the metal polishing thing
    hello there ... i am new to this metal polishing thing and i want to add it to my list so my customers have another choice .... one thing i need to know is what are the rates on the basic stuff... and is there a place i can get them from ... i am working on a set of valve covers seeing how they are small and using the wet and dry sandpaper route they are looking ok but not what i want i will put a pic on later ....
    the rates for polishing and plating are whatever your area will support. are you polishing covers with just sand paper and not polishing compounds , hope not, but thats what your post sounds like
    bill
    http://home.comcast.net/~jhodges87/wsb/index.html
      i am going to start to use the compounds from what i read and what i can tell them look better and will make the job go quicker
        well i just got back from the local home depot and i got a 8 pc kit it has 3 pad's and 5 sticks of compound... and a arbor for a drill is that a good kit to start with ? and where can i find a arbor to convert a dual shaft motor in to a buffer at ... or should i just set up a jack shaft and run 2 wheels at one time ?any input will be helpful.... thanks
          what type pads ?? flat like for a round sanding disc?? i think you will be much happier with buffing wheels.
          bill
            You will need to use a buffing wheel. I tried the home depot stuff when i first started polishing and they're horrible and exspensive. Caswell also sells extender shafts for the motor to make them into a buffer. Good luck.
              To be the best you need to use the best. That's motto.
              You'll never get results like this by using those crappy and over priced homedepo/sears polishing kits.
              Done by me with caswell products and its coated with Zoopseal
                they are cotton buffing pads .... i am going to order some caswell stuff .... the ones i got i may be able to mount them to my grinder ,,,,
                  sounds good very hard to beat caswells buy 1 get 1 free buffing wheels.
                  bill
                    There is NO one on the internet that can beat caswells pricing on buffing wheels. Trust me, i've searched high and low, and i personally havnt found anywhere. Thsoe Home Depot ones are horrible though, especially the loose wheels. They fly apart within 5 minutes of using them especially if you use them on a high speed angle grinder.
                      the pads i got from home depot are junk the did a little cutting but they fall apart the part looks ok but not what i want ... it had a lot af cast marks to start with but i just started with a buffing wheel and compound i should of sanded it them went to compaound ....
                        well i resanded and went over with a new set of pads and i got a nice shine going .. but i still got marks from the old casting ..... i am converting a old motor from my lathe and then try it again .... i will put a pic on in a few days of the before and the after .... this is my first project that will end up on my car .... i still got the whole top end and other parts to go .....
                          i put a pic of the few things i polished in the gallery part of this forum ... they are ok but i still need to work on them more ... thanks for all the help so far
                            what is the fastest cutting compound that caswell sells that will work on alumin.and what size wheel should i put on a 1hp motor?
