Hello everyone, I can't even begin to tell you how happy I am to finally have found a forum about metal polishing. 3 weeks ago I decided I was done shelling out hundreds of dollars to get my motor parts polished. I'm looking for as much advice as I can here. The first thing I've polished is a spark plug cover seen below, but I?m having some issues. I've searched the site and done an immense amount of research, and I just can't seem to remedy the problems I'm having.
Firstly I stripped all the paint off this piece, second I sanded from 80, 180, 300, 400, 600, then wet-sanded 1000, 1500, and 2000. After that I used emery on a 6" spiral wheel coupled to a 5000RPM hand drill, then Tripoli, then white, then red. For the life of me I cant seem to get all the scratches out, and I'm having issues with hazing. What can I do to remedy this situation? I've tried going back and wet-sanding the scratched areas, but as soon as I take the emery compound to the area the scratches reappear. No matter how hard I try I always have areas of haze also.
