needing another finishing step
  • needing another finishing step
    I am having trouble removing my drum buffer marks (on large surfaces- semi trailers) without damaging the shine. It seems anything with microfiber does nothing to remove polish lines and anything with cotton bonnets dulls the finish while removing the polishing lines no matter which polish I use. Is there something that will remove the haze from cotton bonnets and restore the shine? I have tried numerous combinations of polish and tools- cyclo, orbital, hand, makita and can't seem to find an answer
    Re: needing another finishing step
    I did find an answer. Using a fine compound with wool compounding wheel and then orbit polishing the swirl marks out seems to work very well.
      That is useful information. Thank you for following up.
      Richard
