I started polishing aluminium on my bike last winter. I was using a competitors products. You know that BIG automotive restoration catalog.
Well now I've found the real place to be. I am soooo overwhelmed with
the products and info here, I'll neve look any where again.
My question is regarding the options for compounds. I've read all that I could find on our Sponsors web site and can't understand the difference between all the choices. I was using tripoli and white and hoped for the best. Now I read the BBS and find you guys are using Black Emory??
Then I read on and find no less than 11 options. from black,brown, white, fast T-12, alum cut& color A-14, alum buff high lust A-15, non ferr color D-25, non ferr high color D-38, black magic, and then the liquids blue begone and white liq rouge!! Whew what a list I could probley get 1 of each but what a confusing waste.
So what the heck do I choose??
I'm using a converted bench grinder 1/2 or 3/4 hp @34xx rpms.with 6" wheels. I also use a flex shaft with 3" @13xx rpm.
I'm having some of the same problems as I've seen mentioned here::
haze, hairline scratches.
I get good results with wetsanding from 220 to 400.
And then to tripoli on a treated or spiral buff. Or even White on a spiral buff. Some times this leaves some scratches sometimes it doesn't??
When I move over to the loose with white, is when I crash and burn!!
If the wheel has a fresh load on it, I get buildup on the part. If I try to
use less white I end up scratching the part. It's almost like I should just stop with the first buffing step!!
What gives?
What can you guy's tell me that I'm doing wrong?
I will try anything to be more consistent and I want clean clear almost chrome results..
I have Questions but no answers
Steve
What gives?
Steve
