Hand sanding is such a pain. Can I do it by machine? The wheel has compound curves and I was wondering if there are any thing that would work with a machine such as a electric drill?
hand sanding alum. wheels?
Re: hand sanding alum. wheels?
i can t remember last time that i sanded a piece by hand ,to me any hand sanding makes no sense and it s a total loss of time .
there are many Tools out there that can be used to do the job, drills , sanders, variable speed polisher sander, air straight die grinders, air angle die grinders.
then you have just about evrey possible size and type of buffing wheels that you can use with greaseless compounds of different grit size.
Originally posted by baz View Posti can t remember last time that i sanded a piece by hand ,to me any hand sanding makes no sense and it s a total loss of time .
then you have just about evrey possible size and type of buffing wheels that you can use with greaseless compounds of different grit size.Last edited by bcgreen; 03-09-2015, 12:18 PM.
without a picture i don t know whart your Wheel looks like but i can say that on most wheels there is areas that can be done with a da sander , for the rest of the Wheel you can use buffing wheels with greaseless compound with your choice of grit .
