what is a safe paint stripper for alum.... i was blasting it but i noticed i had alot of fine flakes ... do you think that would hurt my part...
paint removal on alum.
I tried this stuff call Stryp-ese. It's a toluolene (or however the hell you spell it) based stripper and it took a LONG time to even bubble the paint on any painted metal. Too much work so now I just chuck it in the blast cabinet and go at it with glass bead. The resulting surface isn't too bad - nothing the greaseless compounds and some elbow grease can't handle. I've had good results blasting at 80psi at around 6-7cfm.
if you want to use paint stripper use aircraft brand it will eat the paint and you too be very carefull with it.
bill
