paint removal on alum.
    USE VHT STRIP FAST
    http://www.caswellplating.com/vht/stripfast.php
  • customandsound
    i used that stuff on my car and it took off 4 coats of paint ... i was not sure about using it on alum. i figured it would stain it to the point it would not buff out
  • bhhodges
    if you want to use paint stripper use aircraft brand it will eat the paint and you too be very carefull with it.
    bill
  • polishinginc
    I usually dont bother with stripping paint. Sanding usually takes care of riding your part of paint.
  • skiddz
    I tried this stuff call Stryp-ese. It's a toluolene (or however the hell you spell it) based stripper and it took a LONG time to even bubble the paint on any painted metal. Too much work so now I just chuck it in the blast cabinet and go at it with glass bead. The resulting surface isn't too bad - nothing the greaseless compounds and some elbow grease can't handle. I've had good results blasting at 80psi at around 6-7cfm.
  • customandsound
    Guest started a topic paint removal on alum.
    what is a safe paint stripper for alum.... i was blasting it but i noticed i had alot of fine flakes ... do you think that would hurt my part...
