I polished my 1st piece of steel today, a shift lever from my 4 wheeler. Took forever to sand all the dings and pits out, but polished up like chrome. Once it was done, I hosed it down with brake parts cleaner then let it sit for about an hour before clear coating with VHT.
Talk about crappy results. The VHT sprayed nice enough, but ended up "migrating" into little bumps as it dried. I was able to strip it all off with laquer thinner and tried again with the same results. I thought it might have been a bit too cool to spray (It was almost 70 here today) so warmed up the can in a bucket of warm water, did the laquer thinner thing, let it dry for 20 mins and tried again. Same friggin' result...
Does this stuff "smooth" out when you heat cure it? I'd hate to have to bead blast cured clear coat off the part and repolish if it doesn't. I do want to keep the part from rusting and Zoop just isn't in the budget right now. Anyone got any tips on how to get this VHT stuff to gloss over? The couple times I tried it on aluminum it came out pretty nice. WTF is the deal with steel
