I have polished two pieces of alum. sheets for a project I am working on and the finish looks great, however I can't touch the surface at all without leaving fingerprints and smudges. Is there a polish that takes care of this problem or would I need to apply some type of clearcoating? Also would the clearcoat adhere to such a smooth surface and would it allow for any flexing of the sheet? I am looking for a simple solution to this problem if one exists. Any help would be greatly appreciated. Thanks
polishing question
I haven't used Zoop but I hear good things about it.
I, like customandsound, use a high quality carnuba wax on my polished surfaces.
I've tried the VHT clear on polished steel and frankly, I'm not impressed. In my experience, it dulls the finish and it definitely discolors when you cure it according to the can's directions.
A clear poly like is used on automotive finishes might work, but I haven't tried it. (yet)
Another option some folks have used is a clear powder coat. You might want to check out the powder coating forum for more info.
