I got pics of my problem. LOOK
  • I got pics of my problem. LOOK
    ok, most of you know my little problem i'm having, i get haze and i'm using an underpowered buffer. here are my tools, and here are my results. please remember that i'm on a budget.
    thanks guys.
    If you notice the haze that it creates on the tube, i was told tat more surface speed would rid that. like a bigger wheel. but i thikn i may need a stronger buffer.
      here is another example. will more surace speed eliminate this?
      it looks great from different angles but i'm trying to make it come outlike chrome.
        are you cleaning the part good before going to another compound ... and what set up are you using .... black /sisal brown / sprial white loose cotton ...... or you can use white on a sprial .... them little compound will work but you will not be happy you may want to order a set from caswell and try them ... and when you buffing try to go side to side instead of up an down ...... on your buffer you can stack 2 8" buffs with no problems
          i have only a 2.1 amp. i want a 6-7 amp.
          i'm using all cotton wheels. i got them at home depot. and they are all 6 inch
            ^^^^ will a 6-7 amp buffer be able to pull a 12 inch loose cotton?
              i got a 6 amp motor that spins 12" wheels ..... them 6" from h-depot are ok .. i use them when i run out of buffs .. i stack 2 on and tear them up ...
              i did a skid plate today and i am going to order the flex shaft
                wow, so that 14 amp motor will tear a 55 inch or something? damn tahts a lot of amps. do u think it's legit? or is he yanking our chains? do u think thats a good buffer to buy, my other thread* of course has it. it's selling on ebay.
