Shaft Extenders
  • Shaft Extenders
    I am going to order a shaft extender for a motor to use as a buffer. The shaft is 5/8" and rotation is CCW. Does the rotation direction determine whether I need a right hand or left hand thread? If so, which would I need for CCW rotation?
    Thanks,
    Rick
    Rickc
    yes it dose... you don't want the buff to come loose when you are working on a part ...... caswell got them in both left and right hand thread ...
    i got them on a motor and the ext. shafts are nice .... you can get the part around more
    PROD SAXLLT5 Extra Long Shaft Adapter 5/8" Bore Left Thread $10.75
    PROD SAXLRT5 Extra Long Shaft Adapter 5/8" Bore Right Thread $10.75
      Shaft extenders
      So, is it right-hand thread for CCW rotation or vice versa? This sounds correct to me.
      Rick
      Rickc
        yes .... if you got a double shaft get both .... i got the std and the ext. ones
          Thanks,
          I'm ordering tonight!!
          Rickc
            any time
