I started playing around with some greaseless compounds in order to sand some aluminum welds after grinding them down.
I used the 80 grit with a 4" wheel on a variable speed hand grinder. I applied the compound and then allowed it to dry before using. What I found was that the compound sat on the surface of the wheel only, when I used it I didn't get a lot done before I had to reapply more compound. I found that lower speeds worked better. I had expected it to last longer. Is this typical
