Hey guys, I'm new to this forum but I'm using the Caswell Powdercoating system now with much success.
Heres my situation. I have a set of 17" Racing Hart rims for my car that I would like to strip and polish to a mirror finish to help accent the podercoated brake calipers I've got on my car. I do not have a bunch buffer but I don't think one would be helpful in this situation since the wheel is so large and unweildy. I have both a 12,000rpm dremel tool (electrical) and a pnuematic die grinder. I was planning on buying the wheels and bobs (as needed) for use with my die grinder. The main concern with this is speed. I'm not able to controll the speed of the die grinder and I'm afraid I may cut too much.
What do you recommend the best tool for this application? Also, I was planning on buying the Jumbo variety pack of compounds but from what I've read I'll only need the black (a lot of it) for cutting and the green for buffing to a mirror finish. The wheels are aluminum but appear to have some sort of finish on them...possibly paint or enamel. I had planned on using a 70/100 medium glass bead to strip the wheels prior to using the compounds. I'm pretty good with a blaster so I won't cut into the metal. Is trhis recommended as a first step as opposed to sanding by hand? I'd really hate to do that when I can strip them completely with a bead blast in about 10 minutes.
Am I missing anything?? Any advice??
