I'm just looking for advice. I plan to start with spiral sewn wheel with emery, then tripoli and finish up with loose cotton with white rouge. Any words of wisdom, different wheels/compounds?
Polishing MC gas tank
Power tools?
I got all the way through to using the tripoli compound before deciding to start over. It was starting to become obvious that it wasn't going to get that mirror finish. I had started with 150 grit so I took it one step up with 100 grit. Got rid of a lot more scratches that were present on my first attempt but I did this one totally by hand, no sanding discs on a drill. It's better but it is still not quite as shiny as Syco's job is in the polishing tutorial. He mentions using an orbital grinder with a sanding disc and a palm sander but the gas tank has recessed, concave areas that I can't quite get a 4" sanding disc into (besides, it was the reason for having scratches) and the palm sander won't work either, it's flat. I am doing the sanding part totally by hand, is there any other way to do this other than by hand or is this where patience, endurance and lots of elbow grease come into play?[img][/img]You don't stop riding because you get old, you get old because you stop riding
get a flexible sanding block ... you can bend them all way's ... load it with paper and sand it til you get a smooth surface ,, then move up on the grit.. once you get to say around 400 grit you should have a dual satin look.... ( when sanding say with 300 go left to right then with the 400 go up and down..but do it with all the grit's ) when you get a nice smooth surface double stack 2 sprial load them with black and go to polishing you want to do it in the cut motion ...you will get a nice mirror shine clean your part... hot soap and water will work ... double stack two new or clean sprial's load it with brown .. repeat the cut motion till you get the tank done ... clean again rake out you wheel's load again now this time go in the color motion till you get a nice shine .... clean you tank again put on a cardboard cut out about 4" load 2 loose cotton on and load with white go in the color motion til you get a highluster shine ....the more time you spend with the black you will remove alot of your scratches that are left over ... the reason i put a 4" cardboard circle on with the loose cotton is to keep the wheel's from folding over to much ... if you want you can get some cotton wheels from caswell the one's that have one line sewn in and use the white on them then clean your part again .. and use the loose cotton and load it with red and go over it the red is moreless just a polish and has not cutting action to it ... it will bring out the shine in your part...
then more you do it the better you will get and the faster you will get .. if you need any help feel free to email me or give me a call .. all my contact infor is on my webpage... www.customandsound.com .... good luck
Thanks for the quick reply. I'll give the sanding block a try, didn't even think of that. I've got one sitting somewhere in the garage...unless the wife cleaned upYou don't stop riding because you get old, you get old because you stop riding
I've got the spiral sewn and a loose cotton wheel being delivered today from you. I had picked up a finger buff and a smaller diameter cotton from local stores but ended up using the finger buff with the emery. I bought it by mistake and was planning on using it for the tripoli, your site says this is an aggressive wheel. Really appreciate the tips. Hopefully, with a little more work at I'll be sending you those pics you've been asking for. Wish me luckYou don't stop riding because you get old, you get old because you stop riding
you got all that stuff from caswell... i don't work for caswell .... i own my own company and i spend my free time helping other out with there polishing and what not problem's .... i am also a happy caswell customer to ...post your pic in the album at the top of the screen ... and let everyone know what caswell product's you used to do your project....
Quick sanding tip. Once you get to the 220 grit, make it wet/dry paper and use LOTS of clean water or kerosene as your lubricant. Elbow grease and a lot fo patience will net you the best results. try to vary your sanding direction 90 degrees or so between grits. It'll help with scratch removal.
Your final look should be bright and satiny with no evidence of scratches. If you've still got scratches, hit it with the sandpaper again.
Customandsound, my mistake. As much as I've seen you reply it was an assumption. Still appreciate all the tips. Skiddz, started with the wet sanding at 220 just like you said. We are thinking alike...scary! I start going with the circular motion at that point also instead of just back and forth but I still vary it by 90 degrees, I guess more of an oval/circular at different angles. It's looking better every time I go over it. I finished the emergy last night and just got into the tripoli. This is my first attempt at something so large. Everything else on the bike is aluminum, much less work to get it polished. Steel takes a while to notice an effect with the sanding but it's getting there. Patience, now there's my first obstacleReally appreciate the advice.
If you're going to use a circular motion to sand, make it figure 8s. You'll cross over your patterns and further reduce scratching. Vary the direction of your 8s as well. Do one grit "vertically" and the next "horizontally" etc..
What type of sand paper are you using? I hear every one say start off with xxx grit and move up from there. My question is what type of sandpaper are you guys using? do you use only sand paper that is made for wet sanding or start with paper that is made for dry then go to wet? FYI: I mainly polish aluminum, I want to start polishing my intake manifold which will need to be sanded.
Thanks in advance for all of the replies I know I will get!
