what product ?
  • what product ?
    I have a set of Aluminum Wheels (bought Cheap) they have been etched (discolored) I think by Chrome Cleaner/Polish. is there a Product I can use to restore its luster. I have a 1/4" drill & a Dremel Tool. My Knowledge of Metals & Polishing is Limited so Thanks for any Advice.
    Going through this very thing on a set of highly oxidized Mickey Thompson forged wheels. I started with a serious scrubbing with wheel cleaner and a couple stiff brushes then rinsed 'em clean with lots of water. I then pulled on the rubber gloves and gave 'em a wash with a muriatic acid solution (Sorry, don't know the ratio - I get this stuff pre-mixed from a local supplier) which gave me a nice clean surface to work with..
    I'm in the middle of wet-sanding the wheels right now and will take that to 400 grit and then I'll dive in with a treated spiral wheel (firm) with tripoli, then a spiral wheel with green then finish up with a loose cotton or flannel wheel and white rouge.
    Your 1/4" drill will probably work ok with some 4" wheels and a mandrel. I've used an old bolt, some washers and a nut to make my own mandrel before. Just put some duct tape over the "head" to reduce any possibility of dinging your wheels as you polish. You'll need a different wheel for each different compound - and be prepared to get filthy.
    Read the online polishing manual here for the "how-to" info you may need to get those wheels looking good.
      Thanks, the wheels I have are not special (Mickey Thompson) so I was hoping for a Product like Flitz (sp?) that I could buff on & like Magic have Shiny Wheels. I'm Checking out the Polishing section now, thanks again.
        the first thing you should do is go to caswell's webpage and on the left side there is a how to buff section read that there are a lot of trick's and tip's .. i dust did a set of wheel's i used acid to get the heavy stuff off and wet sand the whole wheel with 300 - 1000 grit wet ,, hit it with black on a sprial then went right to green then white
