Caswell, please advise
  • Caswell, please advise
    Should I use white lightning stainless compound before, after or in place of white rouge? What difference should I expect to see using the white lightning? I've got a loose cotton that I used the white rouge on already, any problems with using the white lightning on the same wheel?
    You don't stop riding because you get old, you get old because you stop riding
    i would use a new set of pad's ....
