Dremel
  • Dremel
    What supplies would you recommend that fit the Dremel rotary tool (up to 35,000 rpm)?
    I'm mainly refinishing small things like putter heads and golf stuff.
    I'd like to strip old plating and paint off and maybe sand/buff if needed, and then copper plate the items. And maybe.. nickel on top of the copper.
    Thanks!
    Many of life's failures are people who did not realize how close they were to success when they gave up.
    - Thomas Alva Edison
    Re: Dremel
    We have a good selection of felt bobs at http://www.caswellplating.com/feltbobs.htm
    As far as plating goes, a nickel copper combo kit sounds like it would suit your needs. See http://www.caswellplating.com/combo.htm
      Re: Dremel
      Hi!,
      I do alot of Dremel work on the vintage watches that I restore.
      I would suggest getting the full range of buffing componds that are available from Caswell. You will find the one or ones that will do what you need by trial and error.
      I am a newby to Electroplating also and have learned that the stiping and polishing will determine wether or not you get a great,bad or ugly finish on your project.
      Just my 2 cents worth.
      Rusty Armstrong
      Oldwatchhunter
        Re: Dremel
        if the dremel can restore watches then surely I can use it to polish my silver. Is this correct?
          Re: Dremel
          Yes, but dremels turn very quickly and will start removing too much metal if used incorrectly.
          Make sure to use a very soft compound, like blue or red, and a very soft felt bob or dremel mounted buffing wheel.
