Sanding
  • Sanding
    Starting my first project. Was inspired by SYCO i guess. Anyhoo... Stripped the Harley paint off an aluminum piece. I used a metal stripper that worked well using a wire brush on my drill. Had to modify a 1 inch brush down to about 1/4 to get in the crannies. Ok, so figured out how to get in the tight spots for paint removal. How about sanding? I have a Dremel, but even those little sanding barrels are too wide. Any thoughts would be appreciated.
    glassbead and a lot of elbow grease you will get this:
      Is that chrome plating?
      Thanks,
      Andy
        nope.... it was sand blasted then bead blasted to remove the old finish that was chipping and flaking if you look at the arear that have covers they are not shinne unless they got hit wit a buff
