Arbor size of buffs
  • Arbor size of buffs
    I am soon going to upgrade to the casewell 3/4hp buffing motor,currently using a 1/2hp bench grinder that bogs very easily(only 1.5 amps).I am currently using 6" buffs for aluminum.My only problem is the new buffing motor has a 3/4" arbor,whereas my grinder has a 1/2" arbor.Is there anyway I can just drill out a bigger hole in the buffs so I can use them on the new motor?The buffs are fairly new themselves,so I'd hate to hafta buy new buffs just cause of the bigger arbor.
    Mike
    Re: Arbor size of buffs
    Mike
    caswel sell's the buff with the 3/4 hole you can drill the old one out to i have drilled many of them from 1/2" to 5/8's
