Arbor size of buffs
  • Guest's Avatar
    Re: Arbor size of buffs
    Originally posted by mach1man
    I am soon going to upgrade to the casewell 3/4hp buffing motor,currently using a 1/2hp bench grinder that bogs very easily(only 1.5 amps).I am currently using 6" buffs for aluminum.My only problem is the new buffing motor has a 3/4" arbor,whereas my grinder has a 1/2" arbor.Is there anyway I can just drill out a bigger hole in the buffs so I can use them on the new motor?The buffs are fairly new themselves,so I'd hate to hafta buy new buffs just cause of the bigger arbor.
    Mike
    caswel sell's the buff with the 3/4 hole you can drill the old one out to i have drilled many of them from 1/2" to 5/8's
  • mach1man
    started a topic Arbor size of buffs
    Arbor size of buffs
    Mike
