Metals & Wheels
  • Metals & Wheels
    I know using different compounds on the same wheel is a no no, but is there any problem polishing different metals on the same wheel? Say I'm doing Aluminum with a black wheel and want to do a steel piece.
    Should I have a separate set of wheels for steel
    Just wondering ... .
    Thanks!
    Alex
    you can use the wheels on other metal .. but for as cheap as they are you can have a set for steel to ... i use mine till they fit on a die grinder then toss them ......
      Thanks, I kind of figured it would be best to have new wheels but haven't done much with steel yet.
