Hi!
I'm working on an old Shovelhead motor and want to remove the sand casting marks on the engine and polish. The problem is that there are many tight and small places that need to be sanded and the only barrel sand drums I can find are way to much grit. The tightest grit I can find is 120, but I need to get to at least 400-600 before I can put the part to the polishing wheel. Any ideas where I can find those dremel like sanding drums that have a higher grit count?
Thanks for the help!!!
