I am having some serious problems trying to polish an aluminum derby
cover. I am useing a 6" bench grinder with 8" spiral sewn buff and
caswells black. Whenever I make a pass it leaves dull black streaks
one each side of the pass. If I press real hard, it leaves scatches.
I raked the buff before I started and applied compound often. I
don't know if I am using too much pressure, not enough, moving to
fast or slow, or if I don't have enough rpms on the buffer. See pic below, you can see the streaks running vertical in the picture, it's hard to see them because of the clouds reflecting on the part. Feedback please.
Darrin
ok when I figure out how to attach a pic I will get back to you.
Darrin
