Anodizing help please
  • Anodizing help please
    Not sure if this is even the problem, but here it goes.
    I'm working on an intake pipe for a mustang, and I started greaseless at 80 did the whole part and it came out all hazed. I moved up to 120, and still, areas of the part are hazed. So I grabbed my palm sander and put 60 grit on there, and held it on a hazed area for about 30 second and I finally got down to metal, but in that 30 seconds it pretty much destroyed the sand paper. When I hit it with greasless the part/coating rips the greaseless compound off the wheel. Am I dealing with an anodized part? How do I get this coating off?
    Soak in about a 10% Sodium hydroxide(lye) solution. Check it every 3 to 5 min. Wear gloves.
      Where would I find that solution? Thanks for the help.
      ~Brad
        It is the main ingredient in most drain cleaners. ie. Liquid Plumber and such. Mix about 12oz with enough water to make a gal.
          go to ebay and look for Sodium Hydroxide....for a huge tub of it, it's like 5 bucks...
          WWW.DSMETALPROJECTS.COM
          Polishing and Motocycle customization
