So thats my question. When I was dry/wet sanding with my numerous grits of sandpaper I would spend probably 30minutes on each grit size, doing each part at least twice.
I spent only about 3 minutes of buffing on each of the black/brown compounds with the wheels and although they look pretty you can still see minor scratches, Im wondering if this is because i did the cut/color wrong or if because I didnt spend enough time 'buffing' with these compounds.
What length of time should i use as a standard metric?!!??
thank you so much for the quick responses
picasso
picasso
