i"m in the process of sandblasting a set of painted aluminum wheels after that i want to polish them and clearcoat if i remeber correct their is a certain type of polish i need to use is this correct? because if i use any type of polish the clearcoat won't adhear to it could someone suggest a good polish thanks
aluminum wheels
From spending a few years in paint & body, try to stay away from polishes with silicone. It kills adhesion and causes fish-eye. Most buffing and polishing compounds made for paint & body or polishing metals are ok. The ones to watch are the ones meant to maintain the shine after it has been achieved. The main concern will be making sure they are super clean before coating. You'll have to check with the manufacturer on their clear to see if it will go over bare aluminum, not all will and not many will last a very long time. Don't be suprised if you run into alot of pitting when you start sanding. It's normal in cast aluminum.
Originally posted by sswee. Don't be suprised if you run into alot of pitting when you start sanding. It's normal in cast aluminum.
aluminum wheel
thanks for the reply. i don't think i will have a problem with pitting .because parts of the wheels are already polished from the factory. they are 05 dodge hemi wheels i like the style i think they would just look better polished and i think chrome plating would be to shiny. what do you think?
aluminum wheel
I think what they are trying to tell you about pits is that cast aluminum has air bubbles in it. When you start to sand, you may uncover some of them, then you have to keep sanding until those are gone and hope to God you don't get into more. Sometimes you find pits, sometimes you don't, that's just the risk you have to take. And be prepared to do a lot of work, the blastprofile from sandblasting can be hard to get out sometimes depending on the hardness of the alum alloy. You would be further ahead to strip the paint off chemically so the underlying surface is smooth to start with. That is of course if the wheels don't have any knicks in it that you would have to sand and polish anyway. Good luck
Too shiney? What's that? I didn't think there was such a thing. LOL You need to go with what you like. I hope your lucky enough not to run into a bunch of pits but don't hold your breath. Unless you have billet rims there is a pretty good chance you'll hit a few. I've machined precision stainless castings, which are suppose to be high quality, and they have pits. Good luck and let us know how it goes. SS
Take it from me and DO NOT SANDBLAST to remove old finish. Use chemical strippers. I sandblasted a set of Cromodora Daytonas for my '81 Fiat Spider and I had the devil of a time sanding them back down and then polishing. I would have been many hours ahead of the game if I simply stripped them.
Now- having said that, I have new problem. The parts of my wheels that I did not polish, but simple remained sandblasted, are now showing pitting and corrosion, despite simply being in my house for the past few months. What could be causing this- and how do I fix or better yet STOP it??
Gerarddm,
Hard to say without seeing the parts, but more than likely high humidity combined with contaminates impregnated into the parts by sandblasting. You should be able to stop or at least retard the problem with some WD40 or light weight oil to keep the air out until they can be buffed out. Any kind of corrosion or rust requires oxygen and moisture to occurr. SS
aluminum wheels
thanks for the replys: today i went to a auto parts store and bought some aircraft paint remover. done a great job of taking paint off. used a small air grinder with abasive pad wheels to smooth out. at about 60 psi. worked out great found some small pits but the air grinder got most of it out. hopefully sanding will get the rest of it. it don't look to bad. if my camera still works. i'll post some pics to see what you all think. and agian thanks for all the help.
Originally posted by MADMAXXI have some 7 spoke '96 Accord rims I have recently bead blasted they look good. Should I sand before using the wheels and compound? I just got an 8" buffer I ordered today so I would like to be sure of what to do.when in doubt polish it out/ why replace it when you can refinish it
Ive sanded one spoke all the way to 2000grit before I sandblasted just to test it, looked nice just didn't have that bright shine. Should I go up that high or stay at 800.
Why wet?
What should I use to degrease? Mild soap and water?
I will post pics before (sandblasted) and after. I have pics of the rim before I sandblasted them but not on digital camera.
if you sand all the way to 2000, although not bad, it is going backwards to then hit the wheel with spiral/black, maybe even spiral tripoli. it seems like a lot of hand work when it may not be needed. i would sand it all to 800 and do a test run on the wheels and see where your shine is at. i currently do most of the parts i am buffing with a vented wheel and emory, then move straight to loose/white. with what i am doing i can get the shine and no scratches with this combo.try what you have and look for the shine you want before leaving the emory. as for the degreasing i use a hot soapy water mix or most lately a lysol general purpose cleaner. it is yellow and comes in a squirt bottle. it realy melts the stuff away. if i have any small crannies i use a soft toothbrush to get it clean, then flush heavy with water. the best test area is inside the bead area, that way if you have to sand higher you are not backing up, you can just move to a new spot. just a thought. best of luck, and keep in mind polishing is not a science it is an art and all artists are different so find what works best for you. if it your personal part then time might not be a factor, so if it takes longer it is ok.when in doubt polish it out/ why replace it when you can refinish it
