Opinions on buff size on a 1 hp machine
  • Opinions on buff size on a 1 hp machine
    A 1 hp that turns 3450 rpm. Should I stick with the 8" or go to 10 or even 12"? If I did my math right a 10" wheel turns at 8625 SFPM. Too fast, or is there such a thing as far as aluminum goes? Thanks.
    Steve
    As you prolly know max recommended speed is under 8,000 fpm (as I recall), but I would buy one or two 10"-ers and see what happens.
    I think they do have large motors with slower rpms so you can get full benefit of the higher hp without excessive speed.
      I think that's what I'll do. Then I get FHI on 'em. As far as getting one with a lower speed, I'm working on that too. It seems there were alot of 120V AC drives in one of our manufacturing plant that's been shut down. Now all I have to do is locate one. Thanks.
      Steve
        Say, if you can get an extra surplus motor let me know...I could use another motor and would pay something for it.
          Re: Opinions on buff size on a 1 hp machine
          Steve
          i am using a 1.5hp with 12" wheel on alum, bronze and brass. the buff manual says i think between 35-7500 sfm but i know mine is way faster with the big wheels. my point is i have no broblems at this speed in fact it makes faster work if the sanding is right. i finish to at least 400 grit then emory on a vented buff and get the shine i want. then i move to white on loose. i dont use tripoli at this time as i have found i dont need it on the parts i am doing. hope this helps. look at the pics i just posted and judge for yourself
