I know you should only use one compound per wheel but what about using the same wheel on different types of metal. For instance, can I use my sisal wheel with emery on stainless then go right to a brass or aluminum piece without hurting anything? Same with the spiral and loose wheels, or do I need a full set of wheels for every type of compound and metal? Thanks for any help.
Metal contamination on wheels?
Re: Metal contamination on wheels?
Originally posted by chriscurtisI know you should only use one compound per wheel but what about using the same wheel on different types of metal. For instance, can I use my sisal wheel with emery on stainless then go right to a brass or aluminum piece without hurting anything? Same with the spiral and loose wheels, or do I need a full set of wheels for every type of compound and metal? Thanks for any help.when in doubt polish it out/ why replace it when you can refinish it
