H-D Engine/Cylinder Polishing?
  • H-D Engine/Cylinder Polishing?
    I recently had my TP Motor show polished. However, there are spots in the fins where all the scratches were not removed..what is the best way to get into these fins? Loose wheels will not work, as they are not aggressive enough. I was told the \"polishers\" who specialize in these motors use wheels that are 3/8 inch thick. Measuring my fins, that would do the trick. Are wheels this size available, or can they be special ordered?
    Re: H-D Engine/Cylinder Polishing?
    Have you looked at our Finger Buffs?
    These are designed to penetrate crevices and are much more hardy than loose wheels.
    See http://www.caswellplating.com/finger_buff.htm
