Greaseless Coumpounds
  • Greaseless Coumpounds
    Is it ok to use one wheel for muliple greaseless coumpounds?
    i know the answer for the polishing compounds where you need one wheel per compound.
    thank you.
    Re: Greaseless Coumpounds
    You still need different wheels for different grit compounds. They are the same as other compounds, just in a different media.
      Rule of thumb 1 wheel pre... you can clean them good but chances are you will not get all the 80 grit out and so on.....
        thanks for the info.
