Well, I may have taken on more than I can handle but I figure it wouldn't hurt to do a little research to see. Here's the deal, I bought a nickel plated brass NCR cash register made in 1914. I would like to restore it and the first step will be the nickel plating. The plating is worn in several places and in missing totally in others. It was painted gold when I found it.
What I think I know so far. The nickel needs to be removed and the brass polished so the new nickel plating will look polished. What would be the best approach at removing the nickel plating? Using a greaseless compound of some grit? and polishing the brass when the nickel is gone? Or should I start with maybe black emery bar?
Any help would be appreciated.
Thanks
Rick
Thanks
Rick
